3
This discussion topic has been answered Discussion topic: Broadcast or signal failure during recording
This message was authored by: Lesley7407
All my recordings of the Chinese Grand Prix so far, have failed due to broadcast failure or no signal. I have it set to record the series on my Sky Q box. We've had no winds, or bad weather and as they were recorded at 4am I'm assuming it's not due to peak usage in my area. Just getting annoyed at paying for the F1 channel and not being able to record anything.
Avatar for Lesley7407
This message was authored by: Lesley7407 Answer
Re: Broadcast or signal failure during recording
Yes, seems to be my Sky Q box, new arriving tomorrow. Sadly not in time to watch the Geand Prix 😆
@Lesley7407 I know this is no use to you but mine recorded fine both in UHD and in HD so it might just be specific to your box. Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Lesley7407 wrote:
new arriving tomorrow.  😆
@Lesley7407
Remember to remove your viewing card from the faulty box before the doorstep box swap takes place which is unfortunately a common mistake.
Answered - Go to Answer
