Discussion topic: Broadband Connection
This message was authored by: Lkane460
Hello, I have recently changed to Sky broadband. Apps are connected and my TV guide works however the Home Screen says I'm not connected to the internet and this is the same for my Sky Cinema. Can you advise?
Re: Broadband Connection
Hi @Lkane460
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
