Discussion topic: My mini sky box will not connect to the to the network . The tv downstairs is working perfectly
This message was authored by: Susan71
Can someone please phone me
Avatar for Susan71
Level 0 icon
Re: My mini sky box will not connect to the to the network . The tv downstairs is working perfectly
I have rebooted everything in site for the last few mornings & very frustrated with the whole thing.
@Susan71 Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
If you tell us what problem you are having we can try to help you
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Susan71
Try a Network Reset on the mini.
