Discussion topic: Box stuck in reboot every day
Message posted on 22 Feb 2024 05:50 PM
Virtually every morning I find my Q box stuck in reboot. Fan is working very hard and I have to disconnect and reconnect electric. Had same issue with previous box which has been replaced for a different issue. Since mid December
Message posted on 22 Feb 2024 06:05 PM
Re: Box stuck in reboot every day
Make sure all your boxes are on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
Any Q box (including minis) may require a manual software update at times.
For example a replacement Q box or mini or any box that is powered off when an update is released.
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
All Q boxes and minis should be on the same software version.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software.
If you are sure your Q boxes all up to date
Message posted on 22 Feb 2024 06:25 PM
Thanks. I've done all that more than once
