Discussion topic: Cost to upgrade
Message posted on 22 Feb 2024 03:55 PM
Cost to upgrade
I have Sky HD box which routes the signal to 4 TVs. I amd now considering upgrading to Sky Q and want the exact same subscription and same 4 TVs. What is the cost? Sky seems to hide the true costs and when you call them it gets so complicated with the jargon as they try to sell you extra things.
Message posted on 22 Feb 2024 04:15 PM
Re: Cost to upgrade
The best thing to do is to call Sky to see what they will offer you as really none of us here and going to be able to give you a figure.
Message posted on 22 Feb 2024 04:25 PM
Re: Cost to upgrade
Yes it seems to be a big secret. I've called before and gave up because they can't answer a simple question. How much is it to have the same 4 TVs with Sky Q. They want to add this and that. So i'll stick with Sky HD
Message posted on 22 Feb 2024 05:15 PM
Re: Cost to upgrade
@Jeremyduplessis you will need to take the multiscreen subscription which is currently £15 per month unless you can get a discount on it this allows for you to have the main box and upto 4 mini boxes connected at the same time but you can only watch on the main box and 2 mini boxes at the same times unless you have the older 1TB non UHD box which only allows you to watch on 1 mini box
Sky will loan you mini boxes but they do charge anything from £50 to £99 for an admin fee for each mini box
Unless you you are already on the Sky signature subscription sky will change you onto this subscription which some people find it slightly cheaper than the older subscriptions
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 22 Feb 2024 05:24 PM - last edited: 22 Feb 2024 05:24 PM
Re: Cost to upgrade
If you are currently using 'magic eye' (RF) distribution to other TV's then this isn't something that Q supports.
To distribute to other TV's then you'd need to look at 3rd party HDMI solutions - which Sky won't be able to assist you with. (And isn't easy)
As noted above, Sky only offer multiroom (Q mini) which have their own limitations and require a monthly subscription.
Message posted on 22 Feb 2024 06:04 PM
Re: Cost to upgrade
You may, also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
