Discussion topic: Box conection issues
Message posted on 09 May 2024 06:44 PM
Hi when im going on the apps to watch ie disney netflix etc im having to reset the box 2 or 3 times a week
Message posted on 09 May 2024 06:49 PM
Re: Box conection issues
@Tigger2671 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
