Discussion topic: Box Not Connecting to BT Internet
Message posted on 01 Oct 2024 06:59 PM
Hoping someone can help as I have no idea what else to try.
My Sky q has been working fine up until a couple of days ago when it stopped connecting to my internet. My tv itself is still connected but not Qbox. I've switched everything off, unplugged and started again but now it won't accept my password. I'm at a loss as to what to try next 🤷🏻♀️
Message posted on 01 Oct 2024 07:17 PM
Re: Box Not Connecting to BT Internet
Hi @CallieBee23
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 01 Oct 2024 10:16 PM
I have gone through all that again as you said but it won't accept the password for my router. Thank you for replying though!
Message posted on 01 Oct 2024 10:20 PM
Looks like you must be making a mistake with the password @CallieBee23
Message posted on 02 Oct 2024 09:29 AM
I've had this before and it was random. The password was correct. Sometimes it would just reconnect later by itself. Gave up on wifi in the end.
worth trying splitting the 2.4 and 5 GHz SSIDs on the BT router into 2 different names.
Message posted on 04 Oct 2024 09:42 AM
Nah definitely not, I've tried a few times have even disconnected tv in kitchen and put password into it with success so not sure what's going on.
Message posted on 04 Oct 2024 09:44 AM
Oh jeez! How would I go about doing that?🙈
Message posted on 28 Dec 2024 05:36 PM
Same problem and called out Sky Engineer. He said they have endless problems with Sky Q failing to have a stable connection with BT wifi.
