Discussion topic: Unable to pair Sky Q remote to new Panasonic TV, the model we have is not on the Sky list
Message posted on 10 Sep 2024 09:16 PM
Tried the 7&9 buttons followed by the 1&3 buttons on Sky Q remote to pair the latter to new TV but message came up as unsuccessful!, Sky list has a TX-43MX600B on their list but not the TX-43MX800B model that we have, has anyone encountered same problem?, is it worth trying to pair the remote to the 600B model%.
Message posted on 10 Sep 2024 09:19 PM
Re: Unable to pair Sky Q remote to new Panasonic TV, the model we have is not on the Sky list
I'd suspect that the models would have the same setting.
Also try the remote setup in Home - Settings - Setup - Remote Control.
Message posted on 10 Sep 2024 09:23 PM
Hi@oldfella, thanks for reply, tried pairing remote using method you mentioned but it was unsuccessful primarily I believe because the TV model we have is not on the Sky list!, annoying
Message posted on 10 Sep 2024 09:31 PM
Just try using the 'Find it' for me option - my 42MZ980 & GZ980 both work with the first code suggested for Panasonic
Message posted on 10 Sep 2024 09:32 PM
Most models of the same brand will normally have the same remote coding.
With the Q box on with green led try completly resetting your Bluetooth remote again.
Message posted on 10 Sep 2024 09:34 PM
Hi @nigea99, thanks for the reply, I'll give that option a try tomorrow but when trying to pair the remote today there were 25 options to try and none worked!!
Message posted on 10 Sep 2024 09:39 PM - last edited: 10 Sep 2024 09:41 PM
I would be very surprised if the 1st one doesn't work - to my knowledge Panasonic rarely changes its codes & the older TV remotes I have had over the last several years have worked my newer TVs - as I mention my MZ (last years OLED model - the same model year as your MX LED) works with the same codes as my older GZ TV.
Hi@oldfella, thanks once again, I tried that precise method 3 times today to no avail so will try the find it method tomorrow and see if that works
Message posted on 10 Sep 2024 09:43 PM
Hi@nigea99, thanks again, will have another try of the option you advise, fingers crossed I get some success
Message posted on 10 Sep 2024 10:55 PM
One other thing to try is choose Vestel as the manufacturer instead of Panasonic.
Vestel make some of the cheaper Panasonic LCD models for the European market.
Message posted on 11 Sep 2024 10:31 AM
Hi Mister-Dalek, many thanks will have a try with that option too
Message posted on 22 Sep 2024 11:14 AM
I had the same problem went to inputs and it was in there
Message posted on 02 Oct 2024 08:58 PM
I was experiencing the same issue on my new Panasonic model TX-55MZ800B and I tried the suggestion of using Vestel as the model of the TV instead of Panasonic and it worked straight away. Thanks for providing thge suggestion!
Message posted on 01 Dec 2024 07:30 PM
Thanks so much. Ive been having same issue with my new panasonic not being listed. Just tried vestel and 2nd code in worked👍👍👍👍👍👍
Message posted on 28 Dec 2024 05:40 PM
Having the same problem with a new Panasonic and Sky Stream remote.
Vestel doesn't come up as an option. 😟
