2
This discussion topic has been answered Discussion topic: Box Crashed??
This message was authored by: Greatditton
Box Crashed??
Hi. I'm having issues with my sky q mini box. It worked fine until yesterday. When i turned it on it said thatbit lost connection with IP  adress. Ive followed the settings instructions that show on the screen and it just won't reconnect. I've tried absolutely everything. Now I've powered it off at the wall and when it comes back on it says to press the home button when the screen goes blank. I do this and it won't come back on, just an orange light on the box. Please help. Thanks
Re: Box Crashed??
Hi @Greatditton
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Re: Box Crashed??
Hi @Greatditton
Avatar for Greatditton
Re: Box Crashed??
This worked and I've now managed to sort the issue. Thanks for your help @oldfella
