Discussion topic: BSL
This message was authored by: Rogermonika
BSL
I have a Q box sky Tv set. When I record some programmes they come up with BSL signing for the blind. Jow do I disable that?
Re: BSL
@Rogermonika
Post deleted. I misread the aim. Did you mean
@Rogermonika wrote:
they come up with BSL signing for the blinddeaf
Re: BSL
THE BSL aspect is part of the video and cannot be disabled - you might be able to find other showings at  different times that don't have it and maybe find versions without it  from catch up or iplayer etc
This message was authored by: bob1234
Re: BSL
@RogermonikaYou can't remove it but this info may help you to find and avoid it.
https://www.sky.com/help/articles/sign-language-and-signed-programming#
