Discussion topic: Blue light and MR106
This message was authored by: _Martin_
Looking for some help if possible. Have the main sky q box down stairs. The blue neon for the Q logo is constantly lighting up and going out. I've checked the website and reset, holding on power buttons as required. Still nothing. In the house we also have a mini box. This won't come on, the error code for this is error : MR106, I've checked and can't see help for this code.
Re: Blue light and MR106
Hi @_Martin_
Regarding the main Q box.   Try a Reset Settings in the Q box hidden menu.
Once the main Q box is back up and running reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
note: some features may take up to 5 minutes to return
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.   If you are Sky broadband with the latest Sky Max router then you need to treat it as a 3rd party router and still connect the mini to the main Q box.
