Discussion topic: Blank tv
This message was authored by: Rmgriff
Blank tv
My tv screen is blank and / or fuzzy, my sky box is on and I don't know if my satellite dish is working, I don't have any error messages so wonder if it's the tv? Its 19 years old?!
Re: Blank tv
Could be the TV at that age, but worth checking the HDMI cable first, can you change it for a different one?
What happens if you plug the Q box into a different port on the TV?
When was the last time you power cycled the box (unplug at the mains for at least 5 minutes)? Is your box software up to date?
Worth checking these things first as they will be slightly cheaper than a new TV!
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Re: Blank tv
Are you definitely on the right HDMI input?
