Discussion topic: Blank Screen when viewing
Message posted on 03 Jul 2023 12:58 PM
It looks like that i have several issues as the same as other customers but the screen goes black(blank) when viewing programmes from sky sat. and streaming then both go blank at the same time and nothing I do with the remote like pressing home button or selecting another channel or app and it stays blank until i turn everything off and at the wall socket, this is getting very annoying
Message posted on 03 Jul 2023 01:08 PM
Re: Blank Screen when viewing
Hi @Briandl1964
Message posted on 05 Jul 2023 09:44 AM
Thank you for your help in this matter, i will try this asap
