This discussion topic has been answered Discussion topic: BBC Sounds
Message posted on 03 Sep 2025 05:00 PM
bbc sounds app on sky tv has lost audio - everything else is ok
Message posted on 06 Sep 2025 03:59 PM
Not an app I ever use, but I have tested and get the same result, everything works apart from live audio.
I would recommend everyone starts raising this with the BBC directly: https://www.bbc.co.uk/sounds/help/questions/need-more-help/report-fault
I can flag this thread to Sky Community staff, but most of the time, these things end up being an app bug that the provider needs to fix.
sky Q | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Message posted on 03 Sep 2025 05:02 PM
Re: BBC Sounds
Is this on Sky Q, Glass or Stream as it isn't Sky Go related (where you had posted).
Message posted on 03 Sep 2025 05:29 PM
Re: BBC Sounds
this on sky q, sorry I am new to this
Message posted on 03 Sep 2025 05:31 PM
Re: BBC Sounds
No probs, I have moved this to the Sky Q board for you.
Message posted on 03 Sep 2025 05:33 PM
Re: BBC Sounds
Thanks for that
Message posted on 05 Sep 2025 01:28 PM
Re: BBC Sounds
I have the same lack of audio issue, but only on live radio. Does anyone know how to fix it?
Message posted on 06 Sep 2025 03:27 PM
Re: BBC Sounds
BBC Sounds not playing live radio on any station. I've tried resetting the sky box, reconnecting the router, refreshing apps, but nothing seems to make any difference. First world problem I know, but irritating.
Message posted on 06 Sep 2025 05:56 PM
Re: BBC Sounds
Thanks for this, I appreciate you taking the trouble, at least I know now that it's the BBC, I have already raised a case with them & I had one reply asking me for more information - what version of Sounds I have and the System Information of the device. I supplied all this info to them on 3/09 but have not had a reply as yet
Message posted on 06 Sep 2025 05:58 PM
Re: BBC Sounds
I also raised it and sent a link to this thread.
Message posted on 06 Sep 2025 06:12 PM
Re: BBC Sounds
Thanks - watch this space I guess, i can listen on radio but sound quality not as good!
Message posted on 06 Sep 2025 06:27 PM
Re: BBC Sounds
It must be a Sky Q issue.
I have just tried on my TV, Roku and also both my Sky Stream pucks and managed to play Radio 1 to 5 without issue.
It is not an app I use on a regular basis, as do not ever listen to BBC radio.
Would also suggest sending an email to the Sky Viewer relations team to report it;
[email protected]
They will pass on such device problems to a third party, in this case the BBC.
They do respond to emails with any updates for your queries or problems.
Message posted on 06 Sep 2025 06:46 PM
Re: BBC Sounds
Thanks, I will try that but I don't think its a Sky problem as all other apps work perfectly.
Message posted on 06 Sep 2025 07:51 PM
Re: BBC Sounds
The BBC sounds app works ok through our LG tv. Very difficult to know who it is that can fix this!
Message posted on 06 Sep 2025 07:56 PM
Re: BBC Sounds
Thanks for the link.
