Discussion topic: Audio issue
Message posted on 05 Jun 2023 04:57 PM - last edited: 05 Jun 2023 05:01 PM
Audio issue
Hi,
So I'm having a problem with audio on my Sky Q 2tb box.
If i press the home button on the remote, then tv guide and start scrolling I hear a audio glitch, to then get sound back I have to press back then go to the sky home, and the sound triggers again, back to normal, if I just exit the menu sound is not correct.
The other day I was watching the sky F1 race live and it would slowly de sync untill audio stop, changing channel back and fourth fix it for a short time in the end cold reset of the sky q box fixed it.
Some info. My TV is a 2022 Samsung Model QE55S95BATXXU
My Sky Q Box 2tb SW Q220.000.23.00.
Problem seem to be with Dolby Atoms.
Yet both my sky q box and my tv should fully support this.
Message posted on 05 Jun 2023 05:01 PM
Re: Audio issue
@TrebleTA wrote:
Hi,
Some info. My TV is a Samsung QE55S95BATXXU 2022
Hi @TrebleTA
Message posted on 05 Jun 2023 05:04 PM - last edited: 05 Jun 2023 05:06 PM
Re: Audio issue
@TrebleTA wrote:Hi,
So I have done the minor reset. Also I have only just got this new Sky Q box, the other was overheating. But what's this about changing to scr, will try that. It's now on scr, it was on wideband.
Message posted on 05 Jun 2023 05:08 PM - last edited: 05 Jun 2023 05:11 PM
Re: Audio issue
But I dont have a communal dish, I just have my own, but worth a try.
Message posted on 05 Jun 2023 05:10 PM
Re: Audio issue
Put back on wideband, SCR had no siginal.
Message posted on 05 Jun 2023 05:20 PM - last edited: 05 Jun 2023 05:26 PM
Re: Audio issue
When I say the sound glitches, it's like it's trying to play sould out the left side more but it's not right.
Also I can go in to Sky Q setting change Dolby atoms off-on. I get no sound on the sky f1 channel, I then swap channel back and forth to sky F1 and there is sound go in to sky menu do it again switching atoms on and off and I still get sound this time when switching..
Something is not right, is this a faulty sky q box?
As I say, I have only just been given a replacement and dont remember getting this before.
Message posted on 05 Jun 2023 05:54 PM
Re: Audio issue
Message posted on 06 Jun 2023 11:00 AM
Re: Audio issue
After looking on the forum, this seems to be a problem that sky has not fixed for years!!!
Message posted on 06 Jun 2023 06:59 PM
Re: Audio issue
After checking this is on the Sky Sports main event UHD and the Sky Sports F1 UHD.
Reseting/restarting the Sky Q box had no affect.
Just have to live with it...
Message posted on 06 Jun 2023 07:02 PM
Re: Audio issue
Can you just leave your SKY box using Dolby Digital rather than Dolby Digital + as it seems it that which is causing your problem
Message posted on 07 Jun 2023 07:41 PM - last edited: 07 Jun 2023 07:42 PM
Re: Audio issue
Switching channels is easy enouth, yet as I say i'm sure it did not happen on my old over heating sky q box, yet may not of noticed. also if I'm not using dd+ would I not lose that sound quality in UHD/4k Sky cinema d/load's, also apps like Netflix, and they all work fine sound wise, It's just the 2 UHD live channels.
Seems to be something with the sky menu screen triggering it.
Message posted on 07 Jun 2023 08:40 PM
Re: Audio issue
Yes it would also affect the apps - I admit I hadn't really thought of that - Sorry - I use the apps on my TV or Firestick rather than on SKY Q so it didn't come to mind when it should have.
When it comes to films /downloads only those that have Atmos use DD+ (unlike the live UHD channels which now use DD+ as standard) so do you know if you are OK with downloads that do have Atmos (note everything in 4K has) - if Atmos on Downloads is OK then I really don't why it should be different for the live channels
Message posted on 08 Jun 2023 09:36 AM
Re: Audio issue
Aye all works fine its just the two live UHD sky channels, that are giving sound issues and going in to the sky tv menu screen causing problems.
