Discussion topic: Audio drop out
This message was authored by: Batchie169
Audio drop out
Recently upgraded from Sky HD to Q. Now I have intermittent audio drop on Sky channels and recording but not on any apps. I have a Samsung TV and Creative soundboard. Any ideas on how to resolve, as it's driving me nuts? TIA
This message was authored by: ThePope27
Re: Audio drop out
@Batchie169,
Press Home > Settings > Setup > Audio visual, Change Digital Audio output HDMI and Optical to normal.
See if that fixes the audio issues you are facing
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Avatar for Batchie169
Re: Audio drop out
Thanks, I'll give this a go and report back. Many thanks, again.
Re: Audio drop out
I've changed the Optical setting from dolby digital to normal but I'm afraid that it has had no effect on the 'drop out' phenomenon. Can you suggest anything else that might help? Thanks.
Re: Audio drop out
Hi @Batchie169
Re: Audio drop out
Wow. That sounds involved and fraught with risk for an older gentleman but thanks for the advice. Maybe I should just ask a SKY engineer to investigate.  😉
