Discussion topic: Screwn goes blank when watching apps on sky and have to reset to start every rime..
This message was authored by: MelG1
Screen goes blank when watching apps on sky q ..have to reset using home button and start again. Its particularly bad on Amazon Prime app.. need to reset every 10 minutes or so
Re: Screwn goes blank when watching apps on sky and have to reset to start every rime..
Hi @MelG1
If you still have the same issue after the reset first make sure all your Q boxes are on the latest Software.
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
All Q boxes and minis should be on the same software version.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software.
Next step if this doesn't help is  to refresh the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
