This discussion topic has been answered Discussion topic: Apps not working through sky
Message posted on 29 Jul 2025 08:22 PM
Message posted on 31 Jul 2025 05:28 PM - last edited: 31 Jul 2025 05:29 PM
Ok so it's not showing your current subscription when you hit "Get P+"
it's showing you all the options because it has no idea who you are.
To login, you should have chosen a password (and told them your email address) when you first activated P+
Try a password reset via their web platform.
Message posted on 29 Jul 2025 09:10 PM
Re: Apps not working through sky
@GL59 wrote:
None of my apps are opening through sky q (eg netflix, prime etc). They will open up on my phone so it is not an Internet problem but an issue with sky q
@GL59 Have you tried rebooting your main Q box ie
if that doesnt work
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
Message posted on 29 Jul 2025 09:50 PM
Same issue but only Paramount, keeps asking to "get paramount+" but shows my existing package anyway or "sign in". Tried turning off and on to no effect. Engineers menu does not appear either.
Message posted on 30 Jul 2025 02:18 PM
@CarlosF1 wrote:Same issue but only Paramount, keeps asking to "get paramount+" but shows my existing package anyway or "sign in". Tried turning off and on to no effect. Engineers menu does not appear either.
Which engineer's menu? The Q one? How are you trying to access it?
Message posted on 30 Jul 2025 06:03 PM
Yes Sky Q.
Trying it to access engineers menu per Laing1 description in this chat.
Message posted on 30 Jul 2025 06:14 PM
Actually sorted out the engineers menu but refreshing the apps sees no change and no access to Paramount, simply takes me to the sign in/subscription page option. Shows current subscription but no other options other than pay to increase it.
Message posted on 30 Jul 2025 09:59 PM
Can you share a photo of that? Hard to get an idea of what it's doing
Message posted on 30 Jul 2025 10:10 PM
Message posted on 30 Jul 2025 10:32 PM
What happens if you choose sign-in instead on that first screen?
Message posted on 31 Jul 2025 06:43 AM
Requests email and password. I'm not sure if I ever had a password but tried password reset anyway but nothing came of that (I.e no email link to do so).
Message posted on 31 Jul 2025 07:39 PM
It worked! Via the web platform and not via Sky. Thanks very much! 👍
