Discussion topic: Apps not showing on skye box
This message was authored by: Lorna_hilluk
Lightening hit close to our house a few weeks ago and it completely fried my sky q box (and tv).
i now have a new sky q box, this was installed by an engineer following a lot of issues. Now, the apps are missing from the sky q box, i cannot see any recordings on the sky go app and the sky mini box will not work.
i have spoken to sky a lot and nothing seems to be working.
when i go into settings, the sky go app and mini box are showing a cross and when i click to reactivate (although active on my account) they still do not activate.
i have also tried to reset the apps on the box (from seeing advice on other posts on here), this hasn't worked and apps are still not showing.
i have another engineer visit booked but they can't come for another 2 weeks.
im very much on the verge of cancelling everything as i am really unhappy that it's been nearly 2 months since the lightening hit and i still don't have everything back up and running.
any help would be great.
Re: Apps not showing on skye box
Hi @Lorna_hilluk
First thing to do is a Software Update to make sure the box is on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
Any Q box (including minis) may require a manual software update at times.
For example a replacement Q box or mini or any box that is powered off when an update is released.
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
All Q boxes and minis should be on the same software version.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software
Avatar for Lorna_hilluk
i updated both boxes while i was on the phone to the tech team, so both on the same version of software.
Hi @Lorna_hilluk
