Discussion topic: I cannot connect to my sky minibox
This message was authored by: Bryan18
I can not connect to either of my sky miniboxes. I have gone through the usual procedured and also re booted the recantly replaced router box. Can anyone help with this problem.
Re: I cannot connect to my sky minibox
Hi @Bryan18
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
