2
This discussion topic has been answered Discussion topic: Apps disappeared from Sky Q
This message was authored by: Sarah6Times
When we go to apps on Sky Q box they have all disappeared how do I getthem back on there?
This message was authored by: Laing1 Answer
Re: Apps disappeared from Sky Q
@Sarah6Times Have you tried rebooting your main Q box ie
if that doesnt work
then
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
if that doesnt work
then
Avatar for Sarah6Times
Level 2 icon
Thankyou. We had to refresh apps as instructed in engineer mode. But it worked after a while!!
Great shout and much appreciated
