Discussion topic: Angelina pullen
This message was authored by: pullenangelinac
Angelina pullen
No picture keep saying no single?
Re: Angelina pullen
hi @pullenangelinac Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
Re: Angelina pullen
@pullenangelinac
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
