6
This discussion topic has been answered Discussion topic: Adding London TV on Q - does it work?
This message was authored by: ozsat
So I'm trying to add London TV in the add channels option of SkyQ - it is working on my older SkyHD box.
Is anyone finding the channel is not apearing in the list when trying to add?
11656 V 22000 5/6 DVBS QPSL
thank you for trying
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
This message was authored by: xenon81 Answer
Re: Adding London TV on Q - does it work?
It works for me on Sky Q (outside London). Do you already have it stored in your other channels list, possibly under the previous name London Live? If so it won't show in channel scans until you delete it.
Avatar for ozsat
Level 12 icon
Cheers - that is what I thought but didn't want to remove to old name 'London Live' just in case it wasn't adding back.
The old name 'London Live' sometimes changes to 'London TV' but goes back to 'London Live' later.
btw: does your picture on London TV break-up via Sky?
I have not watched for long but no break up for me (NW England)
Checking that transponder on my multisat receiver, it is a slightly weaker transponder
When I was briefly watching it earlier I noticed it kept going blank for a few seconds. It seems to be an issue at London TV's end as other channels on the same transponder aren't affected.
Avatar for ozsat
Level 12 icon
Yes  -that's what I've found - and some picture break-up at times but only part screen.  No pattern to the occurance.
Freely TV feed is OK so I guess it is just on Sky.
This message was authored by: mr.tickle
Works for me (with QPSK, I assume it was a typo).
And to answer your question on another thread - yes, I'm getting some pixellation. About once a minute, ish.  5/6 is pushing the error correction in the direction of "not very robust", but I suspect that isn't the root cause.
HTH!
I do not have a sig other than this message. SkyQ.
Enjoying HDR with 4k Blu-Ray, Amazon, YouTube and gaming since 2016.
