3
This discussion topic has been answered Discussion topic: Accidentally cut sky cable
This message was authored by: Ceebeegeebee2408
My partner accidentally cut the cable inside the house (through the roof) that goes into the back of the sky box. Can the split be rejoined?
Ceebee
This message was authored by: Chodley Answer
Re: Accidentally cut sky cable
Yeah just get an fplug male and female
hi @Ceebeegeebee2408
SKY would probably replace the cable but may charge.
As @Chodley  says it can be repaired with F-plugs & and F-F connector
F ConnectorsF Connectors
Being an intrenal break this should be OK without extra protection  - outside it would need good protection using amalgamating tape or other weatherproof housing
When  preparing the connectors you need to make sure that none of the fine strands of the outer sheathing make contact with the Central core wire - if even one touches it can cause a short circuit & the box will stop providing power to the LNB on the dish
Also, you need to make sure that the outer sheathing copper does make contact with the outer barrel of the F connector - if not, then in this case the voltage won't be supplied to the LNB
You might find this video useful:
Fitting an F Plug
Avatar for Ceebeegeebee2408
Thank you both. Repaired with
F plugs and now back up and running. Phew!
Ceebee
