This discussion topic has been answered Discussion topic: Accidentally cut sky cable
Message posted on 07 Dec 2023 10:54 PM
My partner accidentally cut the cable inside the house (through the roof) that goes into the back of the sky box. Can the split be rejoined?
Message posted on 08 Dec 2023 12:41 AM
Yeah just get an fplug male and female
Message posted on 08 Dec 2023 08:06 AM - last edited: 08 Dec 2023 08:09 AM
Re: Accidentally cut sky cable
SKY would probably replace the cable but may charge.
As @Chodley says it can be repaired with F-plugs & and F-F connector
F Connectors
Being an intrenal break this should be OK without extra protection - outside it would need good protection using amalgamating tape or other weatherproof housing
When preparing the connectors you need to make sure that none of the fine strands of the outer sheathing make contact with the Central core wire - if even one touches it can cause a short circuit & the box will stop providing power to the LNB on the dish
Also, you need to make sure that the outer sheathing copper does make contact with the outer barrel of the F connector - if not, then in this case the voltage won't be supplied to the LNB
You might find this video useful:
Message posted on 09 Dec 2023 08:41 AM
Thank you both. Repaired with
F plugs and now back up and running. Phew!
