2
This discussion topic has been answered Discussion topic: Accessing recordings
This message was authored by: Claire322
Problem with accessing our recording
Re: Accessing recordings
Hi @Claire322
 If you also cannot make new recordings then you may have a hard drive issue.
First try rebooting your Q box.
Failing this
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
@Claire322
What's happening when you try? Any error message?
Hi @Claire322
Failing this
Answered - Go to Answer
