12 May 2024 06:49 PM
my sky q mini box is broken - has errro Mr104 - i have done all possibile to reconect it then i swith the mini box that i belived no workign woth one downstairs which was working and all worked so clearly one minibox is gone - i s a there a way ti order a new one?
12 May 2024 07:23 PM
Posted by a Superuser, not a Sky employee. Find out moreMulti room q box showing error MR104 means your mini box might be a bit too far from the main box to get a reliable signal from it.
Try going to Settings, then Setup - Network - Reset, and at step 2 of 4 on screen, press the WPS button on the front of the main box.
12 May 2024 07:24 PM
Hi @stefano1
MR104 is a connectivity message.
Reboot the mini as above.
