Discussion topic: Accessibility to 2nd Sky mini box
This message was authored by: Bottons
I have 2 sky mini boxes One is operable The 2nd one is not availabe  "cannot use two at same time" I tried to return the second mini box but never received a prepaid/addressed envelope . Could soeone at Sky please resolve one way or the othere Tks
Re: Accessibility to 2nd Sky mini box
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
If you’ve successfully contacted Sky about this they  should send out returns packaging. You can use any packaging as long as it’s secure and you may want to put a note inside with your account number and a list of equipment that is included. This link explains about how to receive an email with your return labels through Royal Mail.
https://www.sky.com/help/articles/return-tv-broadband
Keep your proof of posting safe and indefinitely and if you use Royal Mail’s collect from home service, keep a record of the tracking number.
@Bottons
Perhaps you should note that there is no benefit in returning one mini box if you still have another mini box and a multiscreen subscription
SKY's processes don't really cater for returning individual boxes when customers still have a multiscreen subscription and I think it is more likely that the returned box could be lost in the system
Thus I think it is probably better to keep an unused spare box and return it when you cancel SKY or the multiscreen subscription
