Discussion topic: Accessibility on sky Q
This message was authored by: Janice35
Message posted on 15 Apr 2025 09:08 PM
Can't get past accessibility on Sky Q screen stuck on settings
Find out more
Message posted on 16 Apr 2025 05:04 AM
Re: Accessibility on sky Q
Sky have suggested the following...
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen "Skip & set up later"
- Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
