6
Discussion topic: A lot of my channels are bad quality and or pixelating
This message was authored by s8s888888 This message was authored by: s8s888888
A lot of my channels which are not hd channels are bad quality  music channels  documentary type channels to many to mention some are also pixelated quite bad   i have a 75inch tv  so the quality is very bad
i dont expect perfect quality but a lot are not watchable
i would like a solution if possible  as its been like this for about 6 months
i have been with sky 23 years
This message was authored by TimmyBGood This message was authored by: TimmyBGood Answer
Re: A lot of my channels are bad quality and or pixelating
An SD channel scaled up to UHD over a panel that size is very likely to look pretty bad: no matter how good the silicon in the television is there's just not enough data to work with when 720 × 576 'real' pixels in the content are being to populate 3840 x 2160 on the screen.
Hi @s8s888888
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue I'm afraid that SD channels on a 75 inch TV will be horrendous to say the least.
I assume your TV is 4K 3840 x 2160 pixel (4K UHDTV) Resolution. (8,294,400 pixels of information).
SD Video is 720 x 480 pixel resolution. (345,600 pixels of information).
HD Video is 1920 x 1080 pixel resolution. (2,073,600 pixels of information)
A 4K TV has to display its full resolution of 8,294,400 pixels.
The larger the screen being viewed the more noticeable is the lack of information the screen is receiving.
This message was authored by PandJ2020 This message was authored by: PandJ2020
Do you have HD subscription?
This message was authored by Raider999 This message was authored by: Raider999
Not sure why anyone would buy a 75" UHD TV to watch SD channels?
@Raider999
I guess the SD channels are there, and some don't have an alternative HD broadcast even if the subscriber has the Sky HD add-on.
People generally assume technology can work miracles (particularly when they've paid out for a monster new television), and don't know just how little data is in an SD resolution signal stream.
s8s888888
Didn't answer my question
You  just gave a lecturer
and assuming  I'm expecting hd quality  from sd channels
