Discussion topic: A box not working
Message posted on 11 May 2026 05:55 PM
A box not working
Sky q box stuck on settings, remote control not working even after changing batteries
Message posted on 11 May 2026 06:07 PM - last edited: 11 May 2026 06:08 PM
Re: A box not working
@davies19 Is this the accessibility settings if so try the following...
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
