Discussion topic: A box not working after being disconnected
This message was authored by: JB103
We ga
d to disconnect box due to having work done at home now it will not restart
Re: A box not working after being disconnected
@JB103 wrote:
We ga
Hi @JB103
Try rebooting the Q box again.
If you had to press the button on the front of the Q box (Amber led) then With the Q box on with green led try completly resetting your Bluetooth remote first check the batteries are good.
Then Press and hold 7 & 9 together on the remote until it’s led flashes four times.
