Discussion topic: 3 skyq boxes frozen
This message was authored by: Joshabi
3 skyq boxes frozen
Had skyq 2tb box for years with no problem. Then started playing up so sky replaced it. New box also started freezing daily so sky replaced again. Bizarrely the third box is also freezing daily. Wired connection to super fast Ee broadband. Tried the usual reboot process/amend various settings that sky suggest but still the same issue. Any ideas gratefully received . Thanks
Re: 3 skyq boxes frozen
There are a couple of threads on here about there possibly being an issue with the ethernet ports on the EE routers. Try sticking a cheap switch in between. Or possibly even replacing the router.
