Discussion topic: Potential issues with Sky Q installation
This message was authored by: RESROC
We currently having 3 Sky HD boxes linked with single cables to 3 tvs around our old stone propoerty. The closest to the dish is 10m away and the furthest 40m away. (where we mostly watch tv )
Sky want us to move to Sky Q which involves a new LNB (no problem there) and two cables from the LNB to (I assume) the main Sky Q box . If this is the case, we have an issue, as the  single cable running to the current Sky HD box, (and indeed all 3 boxes around the property ) were discreetly 'buried' 20 years ago. It would be very expensive to expose and replace these cables.
My only thought is to site the main Q box by the TV closest to the dish, where 2 cables can be discreetly sited.
Does that make sense ? (or are there options ?)
If so, do we lose any advantages  siting the 'slave' boxes (needing no cables I believe) next to the other 2 TVs , and in particular the one we most watch ?
Re: Potential issues with Sky Q installation
hi @RESROC
I think I might need to have a think to reply properly.
In the meantime  I think you may wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY +/HD to SKY Q
Note SKY Q boxes connect to the TVs via HDMI cables (although the minis can be connected via AV connectors using a 3rd party mini plug to RCA/Phono AV cable.)
As per my notes the minis connect to the main box via network - wifi or LAN  - it sounds like your topography might be a challenge - who is your Broadband with and do you have ethenet between locations ?
Hi @RESROC   To avoid a world of pain, stick to Sky+HD, or move to Stream if you have fast broadband.
Note there's currently no requirement to do so: Sky+ HD is almost certainly going to last as long as Q* before being discontinued.
*which is approximately the next four years
Only the main box can do 4k
Wifi on Q is flakey. With stone walls it's only likely to be worse. Have you got ethernet run through the house already? This could also affect Stream if you ever try that.
