Discussion topic: 2nd sky box not working
Message posted on 06 Feb 2024 11:04 AM
Main sky box working
2nd sky box on 1st floor not working
Message posted on 06 Feb 2024 11:08 AM
Re: 2nd sky box not working
Hi @Pinky2
Reboot the mini as above.
