Discussion topic: Problem with new sky Q box
Message posted on 06 Feb 2024 12:15 PM
New sky Q box fitted 22nd jan as previous problem with signal since I have been using the box it keeps going off on its own for no reason mainly when I am on the apps, but has done the same on main tv. Sometimes it allows me to come out of the app and try again but after a few tries at this it just goes to a blank screen. Twice now I have had a really loud buzzing from my tv . The sky Q box seems to get quite warm. This has been happening daily since installing the box ,l have checked my signal strength and that is fine .
Message posted on 06 Feb 2024 12:24 PM
Re: Problem with new sky Q box
Hi @mcope
First, as it is a replacement box check that the Software is up to date.
https://www.sky.com/help/articles/sky-software-updates
If or when it is
