Discussion topic: sky box wont turn on. Have changed battery in remote
Message posted on 04 Nov 2023 02:34 PM
will not turn on. Batteries are new. Nothing happening. Was ok this morning. Noidea what is going on
Message posted on 04 Nov 2023 02:58 PM
Re: sky box wont turn on. Have changed battery in remote
The old first option is to turn the box off at the mains. Wait 1 minute then turn it back on and let it reboot. (It's basically a simple computer so "have you tried turning it on and off" is often a solution!)
Message posted on 04 Nov 2023 03:35 PM
Hi @julie592
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
