Discussion topic: 2nd TV Sky HD
Message posted on 23 Jun 2023 09:15 PM
2nd TV Sky HD
Hi,
I have an engineer due next week to change my sky HD to Sky Q. At the moment I have Sky HQ downstairs, and using an old sky box I have freesat to a TV upstairs. Will upgrading to Sky Q stop the TV upstairs working, or if I keep the old box plugged in which is wired straight to the dish, will it still work?
Thanks all,
Message posted on 23 Jun 2023 09:58 PM
Re: 2nd TV Sky HD
@Blue+Ant wrote:Hi,
Thanks all,
You'll need to make sure the engineer fits an LNB that can accommodate both boxes
Message posted on 24 Jun 2023 06:19 AM
Re: 2nd TV Sky HD
Hi @Blue+Ant,
As @Invisiblename says for your freesat box to work you will need a hybrid LNB but these are becoming thin on the ground and not all engineers carry them by default so best to call and make sure that SKY agree to install one and that the engineer is set to bring one
