Discussion topic: My skybox won't connect to the Internet so I cant warch my mini q box
Message posted on 06 Nov 2023 08:58 PM
My skybox can't connect to the WiFi and I can't use my mini box because it can't connect to the skybox. The WiFi signal is fine
Message posted on 07 Nov 2023 09:07 AM
Re: My skybox won't connect to the Internet so I cant warch my mini q box
Message posted on 07 Nov 2023 04:02 PM
I am having exactly the same issue. This has only just started happening. Nothing has changed.. But I can't connect to the wifi. Pushing wps on router to connect the box does nothing and i cant use my mini q because it can't connect.. Please can anyone help?
I have a sky router, main q box and mini q
Message posted on 07 Nov 2023 05:48 PM
Exactly the same problem here too, WiFi is fine but keeps dropping out on mobiles and laptop and won't connect to the sky box
Message posted on 07 Nov 2023 06:45 PM
If you have a Sky router do a reset by pressing the small button on the back of the router and then search for the network on your main Sky Q box. This normally works and is not the same as powering off the router and switching back on.
Message posted on 09 Nov 2023 11:06 AM
Hi @Ben451
An invite was sent but there was no response within 48 hours so it has automatically closed.
If you still need help with this please let us know by posting on the forum again and we will get it escalated through to us.
Tom
