Discussion topic: 2 mini sky q boxes upstairs not working. One remote control not working either
Message posted on 18 Oct 2023 06:43 PM
Upstairs mini q boxes. Cant move from step 1 to step 2 as 1 remote not working either
Message posted on 18 Oct 2023 06:50 PM
Re: 2 mini sky q boxes upstairs not working. One remote control not working either
Hi @Cjr1
First get the remote working.
Assuming it's a Bluetooth remote (Ie with a microphone button for Voice control)
Press and hold 7 & 9 together on the remote until it’s led flashes four times. This will put the remote into infrared mode which will work any Q box with line of sight.
Then make sure that you are pointing your remote at the mini box and see if you can get past step 1 of 2.
If you can then make sure that you are pointing your remote at the Mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
