Discussion topic: Maximum number of recordings
This message was authored by: Brother+Binary
I've just tried to record a program and get a message "...you have too many recordings scheduled at onec. Please go to Settings>Setup>Preferences and set maximum number of recordings to six".
I currently have 5 recordings scheduled.
I go to Settings>Setup>Preferences and there is no option to change the maximum number of recordings.
Any advice gratefully received!
Re: Maximum number of recordings
Hi @Brother+Binary   What is your hardware version, Home -> Settings -> System info -> Hardware version.
hi @Brother+Binary Can I just check that you are doing this on the main box ?
This message was authored by: ozsat
Are you trying to set UHD recordings?  THere is a maximum of two for those still I tink.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Avatar for Brother+Binary
Hi MightyQuin
It's 32B061
Cheers.
Hi Nigea99
Initially I was doing it on a minibox, but I have the same issue on the main box.
Thanks.
Hi Ozsat
Just normal recordings I think. I can do five at a time already.
Thanks.
Hi Nigea99
Thanks.
hi @Brother+Binary can you confirm the Hardware version showing in :
If it is 32Cxx then you have a 1tB that can only record 3 and I don't think any option to change
Thanks for the replies so far - not sure whether I should combine the replies?
I'm off now for the rest of the evening, so if there are more thoughts I'll pick them up later / in the morning.
Hi @Brother+Binary   Are you on software version Q220 (or Q230)?
Just had another look, and now the option has become available on the main box. I'm pretty sure that this wasn't there earlier, but maybe I just missed it.
So, problem sorted. Many thanks for the replies - I didn't know about this forum, and am sure I'll have some other questions in due course.
Glad you have found it & able to set as you wish
If you do have any other questions do feel free to ask and we will try to help if we can
