6
This discussion topic has been answered Discussion topic: Smart Home app error
This message was authored by: Stottie
Sky Smart Home app has signed me out and I'm now getting the error "Oops! Something went wrong" at the login screen. Reinstalled the app and still getting the error...not even able to put in my email address.
Is this just me?
This message was authored by: Highlinder Answer
Re: Smart Home app error
@Stottie  On your mobile are you running private DNS at all to stop ad's? This can be checked by going into settings  and in the search type DNS and you will see private DNS if it is on switch it off and try login again.
@Stottie  Do you have an iPhone or and Andriod device?
Avatar for Stottie
Level 3 icon
Android phone running Android 16
Avatar for Stottie
Level 3 icon
Very odd - it doesn't do it when on a mobile connection - only my home broadband. I also don't get the same issue on the My Sky app?!?
Avatar for Stottie
Level 3 icon
Ah. Thanks! I use UniFi ad blocking and this seems to be the culprit.
@Stottie  You can turn it back on after you login, but you will have to turn it off if the app logs you out. I know this as I have private DNS set and found out this myself.
