Discussion topic: Sky Smart Home app crashing
This message was authored by: MrTix
Device: Samsung Galaxy S25 Ultra
App: Sky Smart Home
(latest version, fresh install)
Issue:
• Live view works fine
• When I open a “person detected” playback clip, the app crashes instantly
• Android shows: “this app has a bug” and kicks me back to home
What I’ve already tried:
• Reinstalled the app
• Cleared cache and data
• Set battery to unrestricted
• Allowed all permissions
• Tested on stable WiFi
• Added app to never sleep mode
None of it fixed the crash.
Looks like a playback or decoding issue with those clips.
However the app worked fine before the update?
Could Sky please take a look into this and investigate.
Re: Sky Smart Home app crashing
Click on the ? On the home page of the Sky Smart home app.
You will find an email address there, that would be the best option to report your issue.
This message was authored by: Morgie74
I am now having the same issue.
Can you share the solution if you find out.
Would suggest sending an email to Sky Smart Home team.
You will find an email address there to report your issue.
Let them know what make, model and OS of your phone/tablet within the email.
Avatar for MrTix
Hi lettice
This information is useless as the app will crash even if you navigate to those options. Sky needs to fix their app
Tix
@MrTix wrote:
Hi lettice
Tix
In that case on the device play stores you can also  find an email address under App support, or use the 'No I still need help' button here to contact the Sky Smart Home team.
https://www.sky.com/help/sky-smart-home-nav/sky-smart-home-app-support/sky-smart-home-app-support-si...
This message was authored by: Kieran3331
having same issue on 8th may
