2
This discussion topic has been answered Discussion topic: Problems with backplate
This message was authored by: DRW2
My smart door bell will not stay on the backplate. Keeps dropping off onto the floor. Anybody else had this problem?
This message was authored by: lettice Answer
Re: Problems with backplate
It can seem a bit tricky at first to seat in the cradle and so to keep it there securely.
I find it's best to angle up the doorbell first when placing in the cradle, so top of doorbell goes in first, then ease  in the bottom of the doorbell, you should then hear a click.
Be careful taking it off, when you have to charge it, so push up the clip at the bottom of the cradle with the tool supplied or a screwdriver pushing the clip up slightly with one hand and pull off the doorbell from the bottom with  your other hand.
It can seem tight at first, try not to force the clip. Have found it tends to loosen up easier overtime.
If you look under the cradle, you will see a small indent on the clip, that is roughly the best place to position your tool when releasing, it's a rough guide, but if you can remember its position, it makes it easier to all work nicely.
@DRW2  The backplate is always a bit tight to begin with, if you can work the small clip hing at the bottom it will eventually stay in place when tried a number of times.
