Discussion topic: out side plan
Message posted on 07 Sep 2026 12:29 AM
out side plan
hi every one could some one let me now when u on unlimited data and it says out side plan what does this mean is that in with your data as well
Message posted on 07 Sep 2026 05:30 AM
Re: out side plan
It would mean it isn't included in your package so what does it say this against as it will be an extra charge applied to your account.
Message posted on 07 Sep 2026 09:24 AM
Re: out side plan
ok just said not in plan and the over say in plan if it's not ture unlimited then is it
Message posted on 07 Sep 2026 09:30 AM
Re: out side plan
@Denzil2301 Data may be unlimited (fair usage limit) but calls are free only to 01, 02 & 03 & UK Mobile numbers, Texts are free to UK Mobiles, picture messaging isn't.
Message posted on 07 Sep 2026 09:39 AM
Re: out side plan
well as i am delivery driver i use google mate and waze so i guess thats chargerable then or not in the unlimited plan is that
Message posted on 07 Sep 2026 11:02 AM
Re: out side plan
@Denzil2301 wrote:well as i am delivery driver i use google mate and waze so i guess thats chargerable then or not in the unlimited plan is that
@Denzil2301 Data for those should be included in your plan, however if you are not a Sky mobile business customer then Sky may well deem your use against the terms and conditions(the service discussed here is domestic use only) and charge you accordingly.
