Discussion topic: is sky mobile compatible in a blackberry phone
This message was authored by: DAM47
I've just opened a sky mobile account, I've put the sim in my blackberry phone, but doesn't appear to be working. Is Sky mobile compatible with a Blackberry phone? Thanks
Re: is sky mobile compatible in a blackberry phone
@DAM47
Has the sim been activated as there is no reason why it wouldn't work so do you have another unlocked device you could try it in ?
Avatar for DAM47
How do I know if the sim has been activated? I received an email from Sky saying that I've transferred over and that my Sky Mobile is up n running.
Thanks for responding
You have to activate the sim via your account so did you do this ?
Avatar for DAM47
I've activated and got my PAC code from my former provider. Handset acknowledges that its Sky, it's got Mobile Networks as Sky
Hi @DAM47  check the APN in the phone settings.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
@DAM47  Is the Blackberry phone 4G comnpatile?  If not it may be 3G and that is being switched off over the country by the end of 2025.
