Discussion topic: esims how do I order an esim
Message posted on 11 Jan 2025 09:43 AM
How do I make an order for an e sim
Message posted on 11 Jan 2025 09:57 AM
Re: esims how do I order an esim
Hi @BK4 look here, choose the plan you want then choose sim type.
https://www.sky.com/shop/mobile/plans?irct=help-sts-buy-a-sim-only-plan-from-sky-mobile
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 01 Oct 2025 03:31 PM
I need an E-sim card for a new samsung galaxy s25 ultra but not sure if I have asked them to order that rather than a plastic one. How can I check or change it?
Message posted on 01 Oct 2025 03:38 PM
Hi @Clarisse+1978 if you receive a physical one then once activated it's a simple process to convert it to an esim. What does your order say you have asked for ?
