7
This discussion topic has been answered Discussion topic: Which is best lightning cable and plug for iPhone 16 Pro Max?
This message was authored by: Kaftangirl
I've just pre ordered the new iPhone 16 Pro Max.
I'm an old woman who hasn't a clue, so I have no idea which lightning cable and usb plug to buy or where from.
I want to extend the life of the battery, so I'm not too bothered about super fast charging.
Can anyone kindly help please (without judging me)?
This message was authored by: 63johnw Answer
Re: Which is best lightning cable and plug for iPhone 16 Pro Max?
It looks like this might be it but can't say for certain @Kaftangirl
https://www.sky.com/shop/accessories/mobile/Power/Apple/30WUSBCPowerAdapter?colour=white
argos have them too as well as Apple
https://www.argos.co.uk/product/9471881
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Hi @Kaftangirl  you should receive a charging lead with the phone, the iPhone 16 has a USB C socket so the lead should have USB C on both ends. You will need a USB C charging plug. You can get these from various sources such as Amazon or Apple etc. I would be wary about getting a cheap one from eBay etc as these can sometimes be dangerous. My advice is use a genuine Apple charger.
Avatar for Kaftangirl
Level 4 icon
@63johnw
Thank you.
I appreciate you taking the time & effort to answer.
I was mistakenly under the impression that iPhones don't come with both a charging cable or, a plug.
Do you know whether Sky sell the Apple usb-c plugs?
I can't seem to find one in accessories shop?
K x
Level 4 icon
@63johnw
Thank you.
Under 'What's in box?':
USB-C Charge Cable
This message was authored by: twilight+princess
iPhones come with a charging cable but not a charger/plug.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
Important to note that the 16 (and last year's 15) use USB-C at the phone end, not the previous (and proprietary to Apple) Lightning socket: these are very much not the same thing.  That's a change forced on Apple by the EU.
