7
Discussion topic: Which is best lightning cable and plug for iPhone 16 Pro Max?
This message was authored by Kaftangirl This message was authored by: Kaftangirl
I've just pre ordered the new iPhone 16 Pro Max.
I'm an old woman who hasn't a clue, so I have no idea which lightning cable and usb plug to buy or where from.
I want to extend the life of the battery, so I'm not too bothered about super fast charging.
Can anyone kindly help please (without judging me)?
This message was authored by 63johnw This message was authored by: 63johnw Answer
Re: Which is best lightning cable and plug for iPhone 16 Pro Max?
It looks like this might be it but can't say for certain @Kaftangirl
https://www.sky.com/shop/accessories/mobile/Power/Apple/30WUSBCPowerAdapter?colour=white
argos have them too as well as Apple
https://www.argos.co.uk/product/9471881
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
Hi @Kaftangirl  you should receive a charging lead with the phone, the iPhone 16 has a USB C socket so the lead should have USB C on both ends. You will need a USB C charging plug. You can get these from various sources such as Amazon or Apple etc. I would be wary about getting a cheap one from eBay etc as these can sometimes be dangerous. My advice is use a genuine Apple charger.
Kaftangirl
@63johnw
Thank you.
I appreciate you taking the time & effort to answer.
I was mistakenly under the impression that iPhones don't come with both a charging cable or, a plug.
Do you know whether Sky sell the Apple usb-c plugs?
I can't seem to find one in accessories shop?
K x
Kaftangirl
@63johnw
Thank you.
This message was authored by PandJ2020 This message was authored by: PandJ2020
Under 'What's in box?':
USB-C Charge Cable
I am just another Sky customer and my views are my own
This message was authored by twilight+princess This message was authored by: twilight+princess
iPhones come with a charging cable but not a charger/plug.
Virginia.
Diamond Sky VIP member.
Important to note that the 16 (and last year's 15) use USB-C at the phone end, not the previous (and proprietary to Apple) Lightning socket: these are very much not the same thing.  That's a change forced on Apple by the EU.
