2
This discussion topic has been answered Discussion topic: Using phone in eygpt
This message was authored by: Carl53
Can I use my phone in eygpt without being charged ?
Re: Using phone in eygpt
@Carl53
Not exactly.
For Egypt it should cost you £2 for each 24 hours use of your home allowance.
You need to ensure roaming and mobile data are turned on in your phone settings and it will kick in when you send a text, make a call or use a small amount of data. Set any spend cap to cover the total number of days you are there. Remember that calls to local numbers are charged extra at international rates and there is now a limit on data use of 25GB per billing period, after which Sky can charge you an extra £2.50 per GB or even suspend your useage duel to overuse.
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
https://www.sky.com/help/articles/sky-mobile-fair-usage-policy.
@Carl53
Not exactly.
Avatar for Carl53
Thanku that's great
